[GRASS-dev] gis.m: cannot get profile from profile tool
Patton, Eric epatton at nrcan.gc.ca
Mon Jul 31 11:52:01 EDT 2006
Hi guys,
I tried the porfiling tool with July 31 cvs, and I can't get it to work. The
y-axis gets assigned correct values for the profile I've drawn, but no lines
get drawn in the profile window. A tcltk window reports "Error: can't read
"cumdist": no such variable"
You can view the output on my ftp site:
ftp://agc.bio.ns.ca/outgoing/Patton/Grass/Bug%20Reports/
~ Eric.
-----Original Message-----
To: Michael Barton
Cc: Grass Developers List
Sent: 7/27/2006 2:33 AM
Subject: Re: [GRASS-dev] gis.m: cannot get profile from profile tool
Michael Barton wrote:
> Hi Moritz,
> Did you select a raster to profile?
Yes, as you can see in the screenshot, it says in the bottom left:
"Profile for srtm_be".
> Third button from the left on the
> profiler toolbar.
> Rather like d.profile, the profiler differentiates between
> a map you use as a background to the profiling line (what is shown in
the
> map display) and the map that you actually use to compute profile
values.
I understand that, but I still don't get a profile. Actually, I
sometimes do not even get the straight blue line you see in the
screenshot (http://moritz.homelinux.org/grass/gism_profile.png), just an
empty graph.
The min and max of the heights on the y axis seem correct, though.
Moritz
grass-dev mailing list
grass-dev at grass.itc.it
http://grass.itc.it/mailman/listinfo/grass-dev
