[GRASS-dev] Driver changes
Hamish
hamish_nospam at yahoo.com
Fri Jun 2 05:33:56 EDT 2006
> I've just committed some changes to the layout of the driver code.
> Specifically, the display/drivers/lib directory has been moved to
> lib/driver, while the bulk of the PNG driver has been moved into a
> separate library in lib/pngdriver.
> It shouldn't have any impact from the perspective of either
> application code or the user, but the changes to the layout (and the
> corresponding changes to the Makefiles) are signficant enough that I
> could have missed something which could cause compilation problems.
> I would appreciate it if people could report successful compilations
> after having updated to the new code, so that I can get an idea of
> when it's had a reasonable amount of testing. I don't want to commit
> the next phase (integration of libpngdriver with libraster) until any
> problems with the latest changes have been ironed out.
Can we tag 6.1.0 before the next lot of changes are committed?
It would make a common basis for before/after tests.
Hamish
