[GRASS-dev] v.out.ascii format=script
Jachym Cepicky
jachym.cepicky at centrum.cz
Sat Jun 3 04:42:23 EDT 2006
hallo,
On Sat, Jun 03, 2006 at 02:52:52AM +0100, Glynn Clements wrote:
> Jachym Cepicky wrote:
> > parsing the output from v.out.ascii format=standard is hard work.
> > Attached patch adds new output format to v.out.ascii called "script".
> > With this output, working with vector data in our scripts should be
> > *much* simpler.
> > If format=script is choosed, each feature will be printed in one line,
> > so e.g.
> > B 6 1
> > 5958812.48844435 3400828.84221011
> > 5958957.29887089 3400877.11235229
> > 5959021.65906046 3400930.7458436
> > 5959048.47580612 3400973.65263665
> > 5959069.92920264 3401032.64947709
> > 1 1
> > will become
> > B:6:1:1 1:5958812.48844435 3400828.84221011:5958957.29887089 3400877.11235229:....
> Many of the tools which you might want to use to process such data
> may have limits on the maximum length of a line.
> Writing scripts which expect all the data on one line is a recipe for
> producing scripts which only work with "simple" maps (or which only
> work with the GNU versions of the standard tools, as they usually
> allocate line buffers dynamically).
> Glynn Clements <glynn at gclements.plus.com>
you are right. I found another solution
thanks
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky at gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060603/4f4864ee/attachment.bin
