[GRASS-dev] New georectifying module in TclTk
    Michael Barton
    Michael.Barton at asu.edu
    Tue Jun  6 00:56:40 EDT 2006
Shows how little I understand C. This will help to try and follow out the
various transformations. Mainly I need the affine transformation.
A question here. Is a single transformation used to generate the projected
points for RMS error calcuations? Or are different transformations used
depending on whether 1st, 2nd, or 3rd order is selected?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Tue, 6 Jun 2006 05:52:54 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Helena Mitasova <hmitaso at unity.ncsu.edu>, GRASS developers list
> <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] New georectifying module in TclTk
> Michael Barton wrote:
>> I will admit from the beginning that since I don't really know C, I may well
>> be missing something. But I think this calls some transformations in
>> i.rectify somehow. As I understand it (also in the i.points and i.rectify
>> docs), you first need to rectify the points using one of the rectification
>> transformations. Then you can go ahead with the compute_transformation()
>> procedure.
> compute_transformation() starts by calling Compute_equation() (in
> imagery/i.points/equ.c), which calls I_compute_georef_equations().
> That computes the best-fit affine transformation (forward and inverse)
> from the control points.
> It then goes on to call I_georef() for each pair of control points,
> measuring the difference between the projected source and the
> destination, and vice-versa.
> I_compute_georef_equations() and I_georef() are both defined in
> lib/imagery/georef.c.
> On entry, the only values which need to have been set are the control
> points.
> Upon completion:
> + group.equation_stat contains 1 if a transformation could be
> computed.
> + group.{E,N}{12,21} contain the transformation coefficients (see
> I_georef() for their interpretation).
> + xres, yres and gnd contain the x, y and diagonal (Euclidian)
> differences for each pair.
> + xmax, ymax and gmax contain the indices of the control points with
> the greatest x, y and diagonal (Euclidian) differences.
> + rms is set to the RMS diagonal error
