[GRASS-dev] G_error in Vlib
Roger Bivand Roger.Bivand at nhh.no
Tue Jun 6 08:14:42 EDT 2006
On Tue, 6 Jun 2006, Wolf Bergenheim wrote:
> On Tue, 6 Jun 2006, Hamish wrote:
> > Wolf:
> >>>> I need G_error (function that does the same thing as G_fatal_error
> >>>> except that it does not exit). Any objections to me adding it (as
> >>>> soon as I get my CVS working again)? I think it can be good to have
> >>>> a possibility of issuing an error message that doesn't call exit.
> > Glynn:
> >>> That's essentially what G_warning() does.
> > Wolf:
> >> Yes but it puts a 'WARNING: '-prefix and not a 'ERROR: '-prefix. (;
> > So what's wrong with "WARNING:" ?   what's the situation?
> It is a fatal error but I can not use G_fatal_error because it calls exit,
> and I need to properly close the vector in v.edit. One such case is for
> instance that the DB connection fails. I still need to build the topology
> or else the vector file is broken (need to run v.build on it before you
> can continue).
In the orginal GRASS 5 compiled R interface, the error handling is passed
to R for exactly this reason to avoid exit(). Then it was:
void R_G_init(char *name) {
	G_set_error_routine(R_handler);
	G_sleep_on_error(0);
	G_gisinit(name);
int R_handler(char *message, int fatal) {
		if(fatal == 1) error(message);
			else warning(message);
		return(1);
where R_G_init() simply sets up the handler and the handler lets you set
the appropriate actions. This of course assumes that your function does
the clear-up, but G_set_error_routine() certainly worked very nicely in
the 5.* codebase except where gislib functions called exit() directly -
this was cleaned later I think by Radim. It is still in current CVS
lib/gis, so I'd try it first, because it will also grab both GRASS errors
and warnings thrown by GRASS functions your code calls.
Roger
> > what about:  G_message("ERROR: zombies");
> Doesn't do the ERROR or WARN magic (like email etc.), and it doesn't beep ;)
> > If it must happen, perhaps it should be called G_nonfatal_error() or
> > something more explicit than G_error()?
> If you have G_error and G_fatal_error and both are documented, then it
> would be quite clear which does what? But if you like G_nonfatal_error
> better then I can live with it too. I don't really care that much about
> the function name, but I do care what it does (;
> --W
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
