[GRASS-dev] v.edit
Michael Barton michael.barton at asu.edu
Tue Jun 6 11:32:35 EDT 2006
This sounds great.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Wolf Bergenheim <wolf+grass at bergenheim.net>
> Date: Tue, 6 Jun 2006 10:30:47 +0300 (EEST)
> To: GRASS developers list <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] v.edit
> Ok now v.edit's add functionality is completed. One can add
> point,line,area,boundary,centroid. Boundaries will not be given a cat.
> Adding an area tries to put a centroid in the geographic mean, and if it
> fails it will exit, with nothing added.
> if you give many co-ordinates when adding a point many points will be
> generated.
> The cat support includes support for many cat's and ranges. This is for
> instance supported:
> v.edit map=test cat=267,347-350,353,356-359 coords=...
> And if there are more points then given cats, the cat will just be
> increased by one. The example above will result in 10 cats:
> 267,347,348,349,350,353,356,357,358 and 359. If you give 11 point the
> eleventh point will get the next cat (which is 360)
> --Wolf
> <:3 )---- Wolf Bergenheim ----( 8:>
