[GRASS-dev] Request to add a GCP file in vector directories
Wed Jun 7 07:22:41 EDT 2006
Hamish wrote:
> * reuse the POINTS file format. It's the same thing with different
> whitespace & comments. It's not so bluky that there's a real need to
> simplify it. The "status" column gets set to 0 when you disable a point
> in i.rectify, this is a good thing.
v.transform already has a defined format for GCPs, and that format is
exposed to the user (i.e. the user is supposed to create the data in
that format). A common format would need to remain compatible (e.g.
change v.transform to allow either 4 or 5 columns).
