[GRASS-dev] Re: grass-dev Digest, Vol 2, Issue 19
Michael Barton michael.barton at asu.edu
Thu Jun 8 18:13:22 EDT 2006
wxPython installed in a snap and the demos seem to run flawlessly. I'm
personally not concerned about having to run x11 or not on my Mac (do it all
the time), but some people find it a little intimidating. My main concerns
are...
1) Is it relatively easy for individuals who volunteer to help develop
[including me :-)] to be able to contribute, regardless of the platform they
work on? In fact it is better if the GUI developers, especially, work on
different platforms to make sure that GRASS works the same on all supported
systems.
2) We should try to limit the quantity and complexity of coding that needs
to be done to the extent possible, compatible with getting high quality
results. This is why a Python-based approach seems very attractive. So we
shouldn't settle on a system that very few people can use or learn and we
should avoid having to maintain multiple versions of the GUI for each
platform. TclTk is good in both respects. So we should maintain this kind of
environment to the extent possible in any new platform.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: <grass-dev-request at grass.itc.it>
> Reply-To: <grass-dev at grass.itc.it>
> Date: Fri, 9 Jun 2006 00:02:00 +0200
> Subject: grass-dev Digest, Vol 2, Issue 19
> You are right, this does not seem that easy, as it is on linux.
> If I understood it correctly, wxpython seems to work for you?
> Jachym
