[GRASS-dev] Re: grass-dev Digest, Vol 2, Issue 19
Glynn Clements
glynn at gclements.plus.com
Sun Jun 11 08:19:10 EDT 2006
Glynn Clements wrote:
> > Export to image formats are still broken (some segv(), some write bad
> > data). Animation via ffmpeg 'works', but again, writes bad data.
> > The 64bit data corruption and segv() issues needs to be fixed before 6.2
> > goes gold. I'll see if I can't hunt down and correct the segv()s this
> > weekend.
> I'm looking into the OGSF image handling stuff right now.
I've committed some changes which should fix the 64-bit issues in the
image dumping code.
