[GRASS-dev] $GISBASE/etc/run what does this do?
Michael Barton michael.barton at asu.edu
Sun Jun 11 18:43:53 EDT 2006
Thanks to both of you for these informative answers. They are very helpful.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Sun, 11 Jun 2006 23:33:18 +0100
> To: David Finlayson <david.p.finlayson at gmail.com>
> Cc: Michael Barton <michael.barton at asu.edu>, GRASS developers list
> <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] $GISBASE/etc/run what does this do?
> David Finlayson wrote:
>> Last night I got GRASS to launch and run entirely from Python. No
>> bourne shell at all. I'm not sure what to do with the signal catching
>> in the Init.sh script. I was going to look them up on Google and see
>> what they do. Then decide whether this is a feature that should be
>> duplicated in Python
>> Does it control how canceling commands (Ctrl+D, etc.) work?
> If you don't run $SHELL via etc/run, the spawned shell will have
> SIGINT and SIGQUIT disabled. In practice, this will typically disable
> Ctrl-C and Ctrl-\ (the codes which generate the signals can be
> changed, but those are the usual defaults).
> AFAICT, the reason that Init.sh disables those signals is so that
> Ctrl-C and Ctrl-\ go to the interactive session shell, not the shell
> running the Init.sh script.
> On a system which supports job control (which is likely to be every
> Unix system still in use), that shouldn't be necessary, as the signals
> will go to the foreground process group, which will be either the
> spawned shell or its children.
