[GRASS-dev] grass6.2?
Michael Barton michael.barton at asu.edu
Sun Jun 11 20:40:00 EDT 2006
I noted the difference because i.rectify reads from the current location and
writes to the location specified by i.target.
V.proj and r.proj read from a different location/map set and write to the
current one.
I'd suggest making v.transform consistent with i.rectify rather than v.proj,
either by implementing a TARGET file or with location and mapset arguments
in the command (the latter seems easier than the i.target way).
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Mon, 12 Jun 2006 01:19:56 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Helena Mitasova <hmitaso at unity.ncsu.edu>, Wolf Bergenheim
> <wolf+grass at bergenheim.net>, <grass-dev at grass.itc.it>, <cavallini at faunalia.it>
> Subject: Re: [GRASS-dev] grass6.2?
> i.rectify, r.proj and v.proj all read from one location and write to
> another (although the two can be the same, they don't have to be),
> while v.transform only uses a single location. I suggest that
> v.transform should be extended to allow a different source location.
