[GRASS-dev] 64bit image issues (WAS: Re: grass-dev Digest, Vol
2, Issue 19)
Glynn Clements
glynn at gclements.plus.com
Mon Jun 12 01:34:24 EDT 2006
Brad Douglas wrote:
> > > > Export to image formats are still broken (some segv(), some write bad
> > > > data). Animation via ffmpeg 'works', but again, writes bad data.
> > > > The 64bit data corruption and segv() issues needs to be fixed before 6.2
> > > > goes gold. I'll see if I can't hunt down and correct the segv()s this
> > > > weekend.
> > > I'm looking into the OGSF image handling stuff right now.
> > I've committed some changes which should fix the 64-bit issues in the
> > image dumping code.
> Thank you! I now have complete images, not quadrants. High resolution
> PPM still crashes, tho:
> #0 0x00002aaab2612d6e in _mesa_GetIntegerv ()
> from /usr/lib64/dri/radeon_dri.so
> #1 0x00002aaaaaad762d in gsd_getViewport (tmp=0xffc4b910,
> num=0xffc4b900)
> at gsd_prim.c:750
> #2 0x00002aaaaaac7276 in GS_zoom_setup (a=0x7fffffc4c64c,
> b=0x7fffffc4c648,
> c=0x7fffffc4c644, d=0x7fffffc4c640, maxx=0x7fffffc4c63c,
> maxy=0x7fffffc4c638) at GS2.c:2395
Try the attached patch.
Index: lib/ogsf/GS2.c
RCS file: /grassrepository/grass6/lib/ogsf/GS2.c,v
retrieving revision 1.8
diff -u -r1.8 GS2.c
--- lib/ogsf/GS2.c 31 Mar 2006 20:51:25 -0000 1.8
+++ lib/ogsf/GS2.c 12 Jun 2006 05:32:24 -0000
@@ -37,7 +37,7 @@
#define NVIZ_HACK 1
-int gsd_getViewport(GLint, GLint);
+int gsd_getViewport(GLint *, GLint *);
static int Surf_ID[MAX_SURFS];
static int Next_surf = 0;
@@ -2392,7 +2392,7 @@
GLint tmp[4];
GLint num[2];
- gsd_getViewport(&tmp, &num);
+ gsd_getViewport(tmp, num);
*a = tmp[0];
*b = tmp[1];
*c = tmp[2];
