[GRASS-dev] New georectifying module in TclTk
Mon Jun 12 02:30:06 EDT 2006
Maciek Sieczka wrote:
> > > It sounds like most of the issues can be avoided by using
> > > i.rectify -c.
> > that is my understanding.
> > > What are the disadvantages of using the -c switch?
> > you have to restart GRASS in the target location and set up the
> > region by hand. Ok if you knew to project a v.in.region box first
> > and can calculate your target resolution
> Could you say how to calculate it?
1) XY to meters:
see "Introduction to GRASS software" by Markus Neteler, 1998 2nd ed.,
part VI, section 1.1.1 (p.27)
2) lat-lon to meters:
1852m per nautical mile
60 nautical miles per degree lat
width of degree lon goes as cos(lat)
so
dist_m_ns = dist_deg * 1852*60
dist_m_ew = dist_deg * 1852*60 * cos(lat)
and
res_ns = dist/rows
res_ew = dist/cols
see also "g.region -e"
Hamish
