[GRASS-dev] GRASS init.sh
Glynn Clements
glynn at gclements.plus.com
Mon Jun 12 08:00:25 EDT 2006
Hamish wrote:
> > [1] The obj_imp table in the database created by tools/sql.sh is the
> > easiest way to locate calls to specific functions.
> It would be nice if that script had a short header comment explaining
> what it was for. "Usage: sql.sh <source directory>" doesn't tell me much.
Usage: after having compiled GRASS, run "tools/sql.sh `pwd`" from the
top of the GRASS source tree.
Essentially, the script runs "nm" on every object file, library and
executable it finds (and "ldd" on all of the executables), processes
the output with egrep/sed/awk, then imports the results into a
PostgreSQL database.
"nm" lists the symbol table of an object file, library, or executable,
indicating whether each symbol is imported into, defined in and/or
exported from the file.
Most of the database tables record which symbols are imported into or
exported from which object files, libraries or executables. E.g. the
"obj_imp" table lists which symbols are imported into which object
files.
You can then use simple queries such as:
grass=> SELECT object FROM obj_imp WHERE symbol = 'I_get_target' ;
object
imagery/i.ortho.photo/photo.2image/OBJ.i686-pc-linux-gnu/target.o
imagery/i.ortho.photo/photo.2target/OBJ.i686-pc-linux-gnu/target.o
imagery/i.ortho.photo/photo.elev/OBJ.i686-pc-linux-gnu/main.o
imagery/i.ortho.photo/photo.rectify/OBJ.i686-pc-linux-gnu/target.o
imagery/i.ortho.photo/photo.target/OBJ.i686-pc-linux-gnu/main.o
imagery/i.points/OBJ.i686-pc-linux-gnu/target.o
imagery/i.rectify/OBJ.i686-pc-linux-gnu/target.o
imagery/i.vpoints/OBJ.i686-pc-linux-gnu/target.o
to discover which files import a given symbol, or more complex queries
such as:
grass=> SELECT DISTINCT b.object FROM lib_exp a, obj_imp b
grass-> WHERE a.library = 'libgrass_form.6.1.cvs.so' AND a.symbol = b.symbol ;
object
display/d.what.vect/OBJ.i686-pc-linux-gnu/what.o
vector/v.digit/OBJ.i686-pc-linux-gnu/attr.o
vector/v.digit/OBJ.i686-pc-linux-gnu/line.o
vector/v.what/OBJ.i686-pc-linux-gnu/what.o
visualization/nviz/src/OBJ.i686-pc-linux-gnu/query_vect.o
(5 rows)
to discover which files import any symbol defined in a specific
library. And so on.
For simple "which files use this function" queries, a database lookup
is quicker and more reliable than grep-ing the source tree.
Assuming that the sql.sh script runs successfully (some of it is
Linux-specific, other bits are PostgreSQL-specific, but the changes
required for a different OS or RDBMS should be quite minor), the
easiest way to figure out what is in a given table (apart from looking
at the name) is to just sample it, e.g.:
grass=> SELECT * FROM stlib_exp LIMIT 5 ;
library | object | symbol
libgrass_manage.a | add_elem.o | add_element
libgrass_manage.a | ask.o | ask_in_mapset
libgrass_manage.a | ask.o | ask_new
libgrass_manage.a | ask.o | ask_old
libgrass_manage.a | copyfile.o | copyfile
(5 rows)
