i.points[.auto] - was Re: [GRASS-dev] grass6.2?
Markus Neteler neteler at itc.it
Mon Jun 12 14:45:06 EDT 2006
On Mon, Jun 12, 2006 at 11:06:17AM -0700, Michael Barton wrote:
> Markus,
> I've been trying to complete a non-x11
> i.points/i.vpoints/v.transform/i.rectify replacement in TclTk.
Michael,
yes, understood and appreciated.
> What you are talking about sounds nice, but I can't do the work in C.
but it is already implemented. Just some "shadow" functions
parallel to the existing point click tool. Since line length
measurement is already there, drawing a line should be easy
(needed for rectify-by-line tool). Also box is already
there from zoom, so drawing a box should be easy (needed for
auto-search-of-GCPs-in-corresponding boxes).
> Also,
> we need something that does not depend on interactive x11 displays.
It doesn't.
> I haven't worked with the linear features modules yet, and so have not tried
> to fold them into the georectifier in this version. I should probably get it
> running completely before trying to expand it.
Of course. I just wanted to remind people that the tool is there.
Once there was quite some interest.
best
 Markus
> > From: Markus Neteler <neteler at itc.it>
> > Date: Mon, 12 Jun 2006 18:40:13 +0200
> > To: Michael Barton <michael.barton at asu.edu>
> > Cc: <grass-dev at grass.itc.it>
> > Subject: Re: [GRASS-dev] grass6.2?
> > Michael,
> > no, the new functions aren't yet in CVS:
> > I wrote:
> > Not related to GUI, but related to a new i.points (as long time promised):
> > http://mpa.itc.it/markus/tmp/i.points.auto_30_mar_2006.tar.gz
> > This should be the merge of i.points + i.vpoints along with
> > homography support (geocoding by lines instead of points which is
> > much easier/faster) and auto-GPC search (based on Fourier correlation).
> > There is a file HANDBOOK inside which explains it a bit. Today
> > I found some raster-map negative row bug, maybe someone wants to give it
> > a try? Would be fun to have that in GRASS soon.
> > So a couple of files (a few) need to the added/modified in i.points to
> > get that functionality.
> > Markus
> > Michael Barton wrote on 06/12/2006 06:37 PM:
> >> Markus,
> >> Are these in the cvs as part of the normal compilation? If so, they should
> >> go into the menu.
> >> I've been tied up in other stuff and so haven't updated the menu much
> >> lately. Also, I was unsure how to do it after Cedric's changes (still unsure
> >> about a few issues).
> >> Michael
> >> __________________________________________
> >> Michael Barton, Professor of Anthropology
> >> School of Human Evolution & Social Change
> >> Center for Social Dynamics and Complexity
> >> Arizona State University
> >> phone: 480-965-6213
> >> fax: 480-965-7671
> >> www: http://www.public.asu.edu/~cmbarton
> >>> Date: Mon, 12 Jun 2006 09:34:23 +0200
> >>> To: <grass-dev at grass.itc.it>
> >>> Michael,
> >>> just curious: do you intend to also include the
> >>> new developments:
> >>> - homology based rectification with lines
> >>> - Fourier correlation based auto search of GCPs
> >>> See:
> >>> http://grass.itc.it/pipermail/grass-dev/2006-March/022051.html
> >>> for link to the source code.
> >>> Markus
> >>> On Sun, Jun 11, 2006 at 11:51:13PM -0700, Michael Barton wrote:
> >>>> Is there a reason to change i.rectify at some point so that it also will
> >>>> read from a different directory and write to the current one? This is how
> >>>> the georectifier works, but I have to switch back and forth between
> >>>> locations/mapsets to make i.rectify work.
> >>>> I have no idea about the locking. But probably not or I would have probably
> >>>> run into it like I did with g.mapset.
> >>>> Michael
> >>>> Center for Social Dynamics & Complexity
> >>>> phone: 480-965-6213
> >>>> fax: 480-965-7671
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
