[GRASS-dev] [bug #4557] (grass) problem with v.surf.rst cross validation
Markus Neteler neteler at itc.it
Fri Jun 16 01:34:35 EDT 2006
On Mon, Jun 12, 2006 at 07:20:34PM +1200, Hamish wrote:
> Maciek Sieczka wrote:
> > Indeed in Grass 6.0x for turning on the CV there is '-v'. In the newer
> > Grass 6.1, as Helena says, there is '-c'.
> > Question for devs - is it good that we have the flags not preserved
> > between 6.0 and 6.1?
> It is bad - any scripts or Books written for GRASS 6.0 should work with
> any GRASS 6.x.
In this case there is no known documentation about it.
-v is reserved for verbose
Generally, it should be possible that authors correct things.
and there is a help option :-)
Markus
> If "-v" is obsolete it should be described as depreciated in the
> flag->description and trigger a G_warning() before setting "-c" to be
> true & then run the module as the user intended.
