[GRASS-dev] GRASS7 wish
Michael Barton
michael.barton at asu.edu
Fri Jun 16 02:05:30 EDT 2006
Something like this was suggested in the GUI roadmap discussions last fall
and winter. It will make upkeep easier in the long run.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: David Finlayson <david.p.finlayson at gmail.com>
> Date: Thu, 15 Jun 2006 10:12:34 -0700
> To: GRASS developers list <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] GRASS7 wish
> As part of my Pythonification of grass project, I'd like to add to our
> GRASS 7 workload:
> Would it be useful to have metadata about our scripts and programs?
> Basically, what I propose is a simple text file that describes each
> command and script in a standard format. I like the format that
> g.parser uses in sh scripts today. I would extend it to include a
> short help and long help description and a sort-of 'magic cookie'
> which describes how to launch the script/program.
> g.parser would be adjusted to read the resource file so there would be
> no user-visible changes. HTML documentation would be built using the
> resource file and an HTML template. GUI's could build their GUI code
> based on the resource file.
> The format should be quick and easy so that script coders can add a
> resource file for their program with a minimum of fuss. (Copy and
> paste a template from the wiki for example).
> What do you think?
> David Finlayson
