[GRASS-dev] Re: [neteler@itc.it: Re: v.surf.rst, v.vol.rst -c, -r flags and other]
Helena Mitasova hmitaso at unity.ncsu.edu
Fri Jun 16 15:52:32 EDT 2006
Markus Neteler wrote:
> Helena,
> find attached the change of the CV flag email,
> related to
>  http://www.intevation.de/rt/webrt?serial_num=4557&display=History
> I would not revert it because -v isn't a good choice
> (verbose flag).
apparently that is why it was changed to -c, it should have been handled
as bugfix. It should be considered a bug fix now.
helena
> Markus
> Subject:
> From:
> Markus Neteler <neteler at itc.it>
> Date:
> Mon, 31 Jan 2005 11:42:23 +0100
> To:
> Jaro Hofierka <hofierka at geomodel.sk>
> To:
> CC:
> Helena <hmitaso at unity.ncsu.edu>
>>> Helena,
>>> On Sun, Jan 30, 2005 at 03:56:47PM -0500, Helena wrote:
>>>> Markus,
>>>> I have the -r, -c changes from Jaro, but I am leaving for a research
>>>> project briefing
>>>> tomorrow morning so I may not have time to test and submit until
>>>> Wednesday.
>>>> If you are around, please let me know whether we have time to submit next
>>>> week or
>>>> whether I should submit without testing or I can give you the files.
>>> before submitting: what are the changes about? Are they bugfixes or
>>> new features? Currently we are in "freeze" mode so that only bugfixes
>>> are allowed. Later a branch will be opened for 6.0.0 and we can
>>> again submit new stuff to CVS (as the 6.0.0 branch will then be separated).
>>> I am sure that you know about all this and things are bugfixes.
>> Markus,
>> These are mostly cosmetic changes, nothing really serious. I think they
>> can be submitted later.
> Jaro,
> cosmetic changes should be fine. If you like, I can submit for
> you or Helena does.
> In parallel we should request Bernhard for CVS write access
> for you (I thought you have it already...).
> Markus
Helena Mitasova
Department of Marine, Earth and Atmospheric Sciences
North Carolina State University
1125 Jordan Hall
NCSU Box 8208
Raleigh, NC 27695-8208
http://skagit.meas.ncsu.edu/~helena/
email: hmitaso at unity.ncsu.edu
ph: 919-513-1327 (no voicemail)
fax 919 515-7802
