[GRASS-dev] i.points, i.vpoints now use G_parser()
Sat Jun 17 03:10:08 EDT 2006
Hamish wrote:
> I just changed i.points and i.vpoints to use the parser, making them
> into "normal" modules.
> This means that, like r.digit, if you try and "Run" them from their GUI
> windows you'll have problems. They need to be invoked in an xterm. I hope
> the GUI experts have a solution.
The solution to all "needs an xterm" problems is to remove the code
which tries to interact with the user via stdin.
