[GRASS-dev] [bug #4450] (grass) g.remove vect: empty dirs in the
$MAPSET/.tmp/$HOSTNAME left
Maciek Sieczka via RT
grass-bugs at intevation.de
Sat Jun 17 07:32:24 EDT 2006
I have built current Grass 6.1 CVS on Ubuntu Breezy with
http://mpa.itc.it/markus/tmp/clean_temp2.c apllied.
Built fine. Empty dirs are still left after 'g.remove vect', but they are
removed after quiting Grass session. Is this what it's expected to do? I'd
prefer each such empty dir be removed right after 'g.remove vect' is done, but
maybe this is not so critical.
Maciek
-------------------------------------------- Managed by Request Tracker
