[GRASS-dev] Re: [bug #4450] (grass) g.remove vect: empty dirs in
the $MAPSET/.tmp/$HOSTNAME left
Markus Neteler
neteler at itc.it
Sat Jun 17 15:18:56 EDT 2006
On Sat, Jun 17, 2006 at 09:00:19PM +0200, Markus Neteler wrote:
> On Sat, Jun 17, 2006 at 07:53:29PM +0200, Maciek Sieczka wrote:
> > > > It is 'g.remove vect' that leaves empty temp dirs in the .tmp.
Now I understand and have the bug reproduced.
In fact g.remove vect=map somewhere creates a
directory in .tmp/ when removing an existing vector map.
It happens in G_find_vector2() which is called in
line 24 of
general/manage/lib/do_remove.c
but I am getting list in the G_find_vector2() and subsequent stuff.
Markus
