[GRASS-dev] Re: [GRASS-user] i.vpoints
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Tue Jun 20 03:08:43 EDT 2006
David,
the configure script is located in the top level directory
of the GRASS CVS files.
You will have to download the *whole* grass6 CVS dir (see
instructions on GRASS download page) or get the weekly
CVS-snapshot.
If you then change into the grass6 dir you will find a
configure script there. Run it with
./configure
Now, I really think you should not mix old 6.0 modules
with 6.1CVS as there have been a myriad of changes in
between versions. I think your better choice is to
install the whole CVS version:
make
make install
and use that for your work instead of 6.0.
(it will install to /usr/local/grass-6.1.cvs by
default). Run it using:
grass61
The CVS version is much more functional and just as stable.
Best,
Benjamin
David Pleydell wrote:
> Dear list users
> We are experiencing difficulty with i.vpoints. The program is displaying our vector layers but is not displaying our vector point layers.
> The vector layers originated as shapefiles created within R and were imported into GRASS 6.0.1 using v.in.ogr called from the GUI.
> Both vector layers display fine with d.vect but in the i.vpoints the layers are not being displayed.
> We considerred updating our i.vpoints executable for something newer off the GRASS CVS repository. This was the first time that we used CVS but we managed to download the apropriate directory
> with the .c files and the Makefile. We saved the downloaded directory as
> /home/dell-2_samba/downloads/temp/grass6/imagery/i.vpoints
> We then tried
> ./configure
> and got the error
> bash: ./configure: No such file or directory
> I wonderred if that meant configure was not installed so I tried
> apt-cache search configure
> but could not see anything suitable.
> How might I best proceed from here for getting i.vpoints working as it should do?
> Many thanks in advance for any helpful pointers
> Dave
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
