[GRASS-dev] v.digit and region
Maciek Sieczka
werchowyna at epf.pl
Tue Jun 20 16:18:44 EDT 2006
Hamish,
Regarding your recent fix for v.digit:
> Log Message:
> restore original region and clear screen on exit.
I think the real problem about v.digit is that it changes resolution
during the digitizing session, not that it changes the region extent.
The latter one, I even like - you can stop digitizing, do some data
viewing in the given location and restart digitizing from the same
place.
Do you think it would be hard to prevent v.digit from changing the
resolution instead of just reverting original region at quit? For me,
it is huge disadvantage that the background map resolution changes as I
zoom in and out in v.digit (not mentioning that it might lead to
crashes in some cases - somehow when the resolution goes too fine
v.digit can't cope with that). And I'd revert to letting the region
extents to change as I pan in v.digit, that's cool.
https://intevation.de/rt/webrt?serial_num=3047
https://intevation.de/rt/webrt?serial_num=2962
Maybe related:
https://intevation.de/rt/webrt?serial_num=3164
What do you think?
Thanks,
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
