FW: [GRASS-dev] grass6.2?
Michael Barton
michael.barton at asu.edu
Fri Jun 23 20:03:01 EDT 2006
I'm copying this to the developer list at Markus' request.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
------ Forwarded Message
Date: Fri, 23 Jun 2006 23:11:47 +0200
To: Michael Barton <michael.barton at asu.edu>
Subject: Re: [GRASS-dev] grass6.2?
Michael,
good to know you back!
Just a quick comment: this message would be useful on the list
as well. It's always a pity if only fractions of important
comments reach the list, hard to get the full picture /even
if one wants to gather old discussion.
Maybe you want to "publish" this message to grass-dev?
thanks
Markus
PS: for i.ortho.photo also the DEM elevation needs to be
extracted when collecting GCPs: so x,y,z instead of x,y
On Fri, Jun 23, 2006 at 11:27:38AM -0700, Michael Barton wrote:
> Brad,
> Thanks for the offer. See below.
> Michael
> phone: 480-965-6213
> fax: 480-965-7671
> > From: Brad Douglas <rez at touchofmadness.com>
> > Reply-To: <rez at touchofmadness.com>
> > Date: Wed, 21 Jun 2006 02:19:09 -0700
> > Cc: Markus Neteler <neteler at itc.it>
> > On Mon, 2006-06-12 at 11:06 -0700, Michael Barton wrote:
> >> Markus,
> >> I've been trying to complete a non-x11
> >> i.points/i.vpoints/v.transform/i.rectify replacement in TclTk.
> >> What you are talking about sounds nice, but I can't do the work in C. Also,
> >> we need something that does not depend on interactive x11 displays. I
> >> haven't worked with the linear features modules yet, and so have not tried
> >> to fold them into the georectifier in this version. I should probably get
it
> >> running completely before trying to expand it.
> > Need some help? I'm quite interested in these modules, also. I can't
> > help with the TclTk all that much, but I know C well enough to be a bit
> > dangerous. :-)
> > I'd really like to reimplement the rectification code with GDAL, which
> > will cut down on the amount of code quite a bit.
> Can you look back on the developer's list for discussion of what needs to be
> done for this. Glynn Clements outlined it in detail to the list, with copies
> to me. It should postdate my initial post on committing the georectifier to
> the CVS. Your help would be much appreciated. But need to coordinate with
> Glynn.
> > Also, I wish the X11/GUI decisions would get decided. I think we've
> > heard enough testimony. Time to summarize and vote. It's really
> > holding GRASS back. :(
> As far as I'm concerned, the decision to replace x11 displays and
> interactive x11 question/response as the basis for the GRASS GUI was made
> several months back. This is the only way to make significant improvements
> to the user interface.
> I am aiming toward as much of an x11-less GUI as possible for 6.2, using
> TclTk. The current TclTk GUI is nearly x11-free. Georectification (almost
> done) and digitizing (not done) are the only remaining major functions to
> still require x11 interactive displays.
> The major question now involves replacing TclTk as the basis for the future
> GRASS GUI. The 2 strongest contenders are Python interfaces to GTK and
> wxWidgets. WxWidgets seems to have the best cross-platform support, while
> GTK is somewhat more mature and reported to be a bit easier to work with. I
> and a couple other folks are trying to do a test wxPython (Python extended
> to use wxWidgets) GUI to see if it runs equally well on all supported GRASS
> platforms.
> The new GUI platform would be the basis for GRASS after 6.2. In any case, we
> need to move away from the now-archaic x11 display and interactive interface
> system. My understanding is that this will not be dropped for now (i.e.,
> XDRIVER will continue to exist), but GUI development will no longer depend
> on x11 displays or x11 interactive interfaces.
> IMPORTANT NOTE: This does NOT mean lack of a command line interface (CLI),
> GRASS command access, or the ability to extend GRASS through shell scripting
> (or any other kind of scripting), only that the CLI and GUI will not REQUIRE
> displays or interaction in an x11 terminal.
> Michael
> > Brad Douglas <rez touchofmadness com> KB8UYR
> > Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
------ End of Forwarded Message
