[GRASS-dev] clean_temp rewritten
Mon Jun 26 02:32:35 EDT 2006
fyi
>>>>1. snprintf() is C99; not all systems have it.
>>>So far it is implemented a few times in GRASS:
>>> ./lib/gis/user_config.c
* LIBRARY:      user_config.c  -- Routines related to the user's GRASS
*               configuration, tmp, and miscellaneous files.
 * NOTE: As of 2001-03-25 this file is not hooked up.  It is provided as a
 * candidate for handling $HOME/.grass files and subdirectories.  There may
 * be more functionality desired (such as deletion routines, directory globs).
static char * _make_toplevel()
char * G_rc_path()
Hamish
