[GRASS-dev] clean_temp rewritten
Mon Jun 26 02:45:22 EDT 2006
Glynn Clements wrote:
> If the code was otherwise robust against buffer overruns, then
> ignoring the length argument would be a genuine issue. However, there
> are probably hundreds of places where a buffer overflow could occur,
> so one more doesn't make that much difference.
Even so, we should have a robust solution and attempt to fix overruns in
the libraries and some core modules when identified.
Journeys of 1000 miles...
Hamish
