[GRASS-dev] [bug #4739] (grass) r.out.gdal: multiple createopt impossible
Markus Neteler neteler at itc.it
Mon Jun 26 06:24:58 EDT 2006
On Mon, Jun 26, 2006 at 12:04:24PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4739
> Subject: r.out.gdal: multiple createopt impossible
> Platform: GNU/Linux/x86
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 2006-05-23
> According to manual, for 'createopt' "Multiple options may be listed". Trying:
>  r.out.gdal input=map type=Byte output=map.tif createopt="COMPRESS=DEFLATE"
>  createopt="TFW=YES"
> It doens't work:
>  0Warning 5: COMPRESS=DEFLATE,TFW=YES value not recognised, ignoring.
> Same happens for:
>  createopt="COMPRESS=DEFLATE","TFW=YES"
Implemented in CVS.
Example:
 r.out.gdal elevation.dem format=GTiff type=Int16 output=elev_dem.tif \
            createopt=TFW=YES,COMPRESS=DEFLATE
should now work. Same for metaopt.
Markus
