[GRASS-dev] i.points, i.vpoints now use G_parser()
Michael Barton michael.barton at asu.edu
Wed Jun 28 14:38:52 EDT 2006
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Wed, 28 Jun 2006 16:31:57 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Hamish <hamish_nospam at yahoo.com>, <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] i.points, i.vpoints now use G_parser()
> Michael Barton wrote:
>> So I should display a forward RMS and a backward RMS.
>> For each point, should I just display a single error distance or try to
>> display reverse for raster and forward for vector?
> I suspect that you should probably display both.
> AFAICT, either of the two points in a GCP pair can be misplaced just
> as easily. Also, when you are entering the control points, do you
> actually know whether they are going to be used for transforming a
> raster or a vector (or both)?
> Maybe you could determine the size of the source and destination
> regions, and convert the absolute errors to a proportion of the
> region's size. That would allow you to sensibly compare forward and
> backward errors.
If I normalized them to percents (I'd better use a percent sign so as not to
confuse anyone), would this make sense to people? Or will people prefer to
see the distance in actual map units?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
