[GRASS-dev] vm_allocate error
Helena Mitasova hmitaso at unity.ncsu.edu
Thu Jun 29 11:38:43 EDT 2006
Brad Douglas wrote:
> Helena,
> Those are error messages from the operating system kernel.  It has
> literally run out of RAM (or it thinks it has - e.g. 32bit coding on
> 64bit system).
> I suppose it may depend on where it runs out of memory in the file as to
> whether the results are displayable or not (but I would expect it to be
> incomplete, regardless).
> I didn't realize v.proj was such a demanding memory hog.
Brad, thank you, this helps. When you look at the output it is not
v.proj itself that is the problem but
the usual topology building - so it converts the points and then builds
the topology and that is when
it runs out of memory - a well known problem. Except that this is a
little bit nicer behavior than the usual
machine freeze that you get when building topology on a large file.
With v.surf.rst it looks like we have a problem because there is no
reason it should be running out of memory
when computing the segments, hopefully I will be able to find and fix
that one but the topology stuff
seems to be beyond what anybody can do for now.
Helena
> On Wed, 2006-06-28 at 22:38 -0400, Helena Mitasova wrote:
>> has anybody seen (or have an explanation) for the following
>> vm_allocate error
>> that we got from v.proj when projecting rather large point file on
>> Mac running recent CVS GRASS
>> (I was able to run v.proj with the same data on a  FC5 machine
>> without problem).
>> We got similar error from v.surf.rst after 86% done on 5000x5000
>> raster (but I was able
>> to compute bigger raster on a smaller mac laptop). I am trying to
>> find out whether it is the data
>> or something specific to Mac (a 2GB memory machine) or a bug that is
>> causing this error.
>> thanks, Helena
>> GRASS 6.1.cvs (jockeyspft):~ > v.proj input=earl030921oregoni
>> location=coastll mapset=PERMANENT output=earl030921oregoni
>> Input Projection Parameters: +proj=latlong +a=6378137 +rf=298.257222101
>> +no_defs +towgs84=0.000000,0.000000,0.000000
>> Input Unit Factor: 1
>> Output Projection Parameters: +proj=lcc +x_0=0.6096012192024384e+06
>> +y_0=0
>> +lon_0=79dw +lat_0=33d45'n +lat_1=36d10'n +lat_2=34d20'n +a=6378137
>> +rf=298.257222101 +no_defs +towgs84=0.000000,0.000000,0.000000
>> Output Unit Factor: 0.3048006096012192
>> Creating vector file...
>> Building topology ...
>> Registering lines: v.proj(2057) malloc: *** vm_allocate(size=8421376)
>> failed (error code=3)
>> v.proj(2057) malloc: *** error: can't allocate region
>> v.proj(2057) malloc: *** set a breakpoint in szone_error to debug
>> node.c:48: failed assertion `n'
>> Abort trap
>> --- end printout 030921-----
>> Although the vector was created, I wasn't able to display it.  On the
>> contrary, I was able to display the 030916 vector despite reporting a
>> similar error without abortion:
>> ---- error printout 030916---
>> (v.proj(753) malloc: *** error: can't allocate region
>> v.proj(753) malloc: *** set a breakpoint in szone_error to debug
>> v.proj(753) malloc: *** vm_allocate(size=24088576) failed (error code=3)
>> ---- end error printout 030916---
>> there may be a huge segment in the masked area, but the error message
>> is not comming from the rst code
>> v.surf.rst input=L18 layer== dmax=3.0 dmin=1.0 elev=surf500501Lidar
>> maskmap=MASK zmult=1.0 tension=40.0
>> smooth=10.0 segmax=20 npmin=120
>>    86%
>> WARNING: taking too long to find points for interpolation--please change
>>           the region to area where your points are. Continuing
>>           calculations...
>> v.surf.rst(1340) malloc: *** vm_allocate(size=8421376) failed (error
>> code=3)
>> v.surf.rst(1340) malloc: *** error: can't allocate region
>> v.surf.rst(1340) malloc: *** set a breakpoint in szone_error to debug
>> code=3)
>> code=3)
>> code=3)
>> ERROR: G_malloc: out of memory
>> Helena Mitasova
>> Dept. of Marine, Earth and Atm. Sciences
>> 1125 Jordan Hall, NCSU Box 8208,
>> Raleigh NC 27695
>> http://skagit.meas.ncsu.edu/~helena/
>> On Jun 28, 2006, at 8:24 PM, Helena Mitasova wrote:
>>> On Jun 17, 2006, at 5:26 AM, Māris Nartišs wrote:
>>>> Re-posting, as previous mail was larger than lists accept.
>>>> Hello all GRASSers.
>>>> GRASS CVS contains new module r.lake. This module can be used to
>>>> create lake
>>>> maps if only place and lake level is known. To use this module You
>>>> need
>>>> terrain raster map (DEM), water level for lake in same units as
>>>> DEM values
>>>> and coordinates for any point in lake.
>>>> Module uses 3x3 sliding window to fill whole area connected to
>>>> seed point (can
>>>> be coordinate pair or already existing raster map) and having
>>>> height values
>>>> below water level. Output map will have lake depth in DEM units. More
>>>> information about module is in help page.
>>>> I use this module for palaeolake reconstructions based on single
>>>> shore line
>>>> measurement. It also can be usefull for reservoir planing,
>>>> creating maps with
>>>> scenarios for lake level changes etc. Unfortunately mailing lists
>>>> does not
>>>> accept attachments larger than 100kb - no sample images with
>>>> r.lake in
>>>> action.
>>>> Currently this module has some limitations and I ask for help to
>>>> other GRASS
>>>> developers to help me to fix them.
>>>> Most important - module is NOT large file safe.
>>>> Lake volume calculations work only if DEM is in meters.
>>>> G_area_of_cell_at_row() always returns cell area in square meters,
>>>> but I
>>>> could not figure out how to get information about DEM units. Thus
>>>> if both are
>>>> in meters, volume is correct, else not ...
>>> we have already discussed this in relation to r.slope.aspect which
>>> has the same problem,
>>> currently it gives warning when x,y in feet is converted to meters
>>> so that user
>>> can check and make sure that the elevation is in meters too.
>>> There is no place currently in GRASS to store DEM z-units (and
>>> vertical datum) so it is left to
>>> the user to make sure that the units are handled correctly (big
>>> pain here in US where
>>> feet and meters are about equally common and mixed in various ways).
>>> I believe that for GRASS7 we should include the vertical datum and
>>> units information for each location even if we
>>> do not provide the transformation tools - this should help users
>>> better manage
>>> their elevation and volume data and they can use external tools to
>>> convert the vertical datum
>>> for the data that they want to import to the datum used in the
>>> GRASS location.
>>> For example there is an official open source code for US coastal
>>> vertical datums conversion
>>> available here (it is written in Java2 though)
>>> http://chartmaker.ncd.noaa.gov/csdl/vdatum.htm
>>> This would not prevent the users to mix misc. vert. and horiz.
>>> datums and units in their database
>>> (at their own peril as I have learned the hard way), but it will
>>> encourage the management
>>> of data in a well defined coordinate system and units in all 3
>>> dimensions.
>>> Helena
>>> P.S. I would like to add this suggestion to the wiki development
>>> page - apparently it should go
>>> under Plans but it does not fit into Overview, should I add it to
>>> sand box?
>>> Or should we start a GRASS7 proposals/suggestions/todo section?
>>>> Thanks to all who helped me to code this module.
>>>> Any comments, ideas, enhancements - always welcome.
>>>> Maris Nartiss.
Helena Mitasova
Department of Marine, Earth and Atmospheric Sciences
North Carolina State University
1125 Jordan Hall
NCSU Box 8208
Raleigh, NC 27695-8208
email: hmitaso at unity.ncsu.edu
ph: 919-513-1327 (no voicemail)
fax 919 515-7802
