[GRASS-dev] change permissions for mapsets
Glynn Clements
glynn at gclements.plus.com
Fri Jun 30 11:16:59 EDT 2006
Otto Dassau wrote:
> I have a question about g.access.
> When I try to change permissions for mapset PERMANENT, it does not work:
> -> access to PERMANENT must be open, nothing changed
> when I try to change permissions for another mapset test, it works:
> -> Everyone now has access to mapset test
> Does this mean, that I cannot use mapset PERMANENT together with other users?
> Or how can I resolve/change this?
A few notes:
1. You cannot select a mapset as the current mapset (where any new
maps will be created) unless you own the mapset directory; having
write permission isn't sufficient.
2. To change the permissions for a mapset, you have to own the mapset
directory.
3. No-one should ever have the PERMANENT mapset as their current
mapset. GRASS doesn't actually enforce this, although it probably
should.
