[GRASS5] Segfault of v.in.ogr with OGR-layer
Stephan Holl
holl at gdf-hannover.de
Wed Mar 1 03:15:36 EST 2006
Hello list,
For completeness of my own thread :-)
the problem of this segfault was a missing environment-variable
ORACLE_HOME which was needed by gdal when compiled against the Oracle
OCI 9i interface.
Exporting the variable and writing this into e.g. ~/.bashrc solved the
problem permanently.
echo "export ORACLE_HOME=/some/path/OraHome" >> ~/.bashrc
Best
Stephan
On Mon, 27 Feb 2006 11:50:15 +0100 Stephan Holl
<holl at gdf-hannover.de> wrote:
> Hello list,
> On Wed, 22 Feb 2006 17:00:36 +0100 Stephan Holl <holl at gdf-hannover.de>
> wrote:
> > Dear List,
> > I am trying to import an ogr-Datasource into GRASS using v.in.ogr.
> > The following error appears:
> > (gdb) r dsn=OCI:user/pw at oracle.galileo out=a layer=SPEAR_SOILS
> > Starting
> > program: /home/holl/cvs/grass_HEAD/dist.i686-pc-linux-gnu/bin/v.in.ogr
> > dsn=OCI:user/pw at oracle.galileo out=a layer=SPEAR_SOILS [Thread
> > debugging using libthread_db enabled] [New Thread -1234180384 (LWP
> > 21724)]
> > Program received signal SIGSEGV, Segmentation fault.
> > [Switching to Thread -1234180384 (LWP 21724)]
> > 0xb79031b0 in strcmp () from /lib/tls/libc.so.6
> > (gdb) bt
> > #0 0xb79031b0 in strcmp () from /lib/tls/libc.so.6
> > #1 0xb7a254f2 in G_find_key_value (key=0x0, kv=0x817d1b0) at
> > key_value1.c:107 #2 0xb7a25907 in G_lookup_key_value_from_file
> > (file=0x0, key=0x0, value=0xbfdc1600 "", n=80) at key_value4.c:49 #3
> > 0xb7aefdf1 in GPJ_osr_to_grass (cellhd=0xbfdc1650,
> > projinfo=0xbfdc27c8, projunits=0xbfdc27cc, hSRS=0x81517b0,
> > interactive=0) at convert.c:352 #4 0x0804d4e8 in main (argc=0,
> > argv=0xbfdc5da4) at main.c:384
> > I received this on a fresh CVS-HEAD-Checkout of today.
> > When I do this with the ogr2ogr-tool I can access the datasource
> > fine, everything works. But GRASS does not :-(
> > Perhaps anybody could give me some pointers where I should dig
> > deeper?
> > A bt full backtrace from gdb is provided here[1] (longish).
> > Thanks in advance
> > Stephan
> > [1] http://www.gdf-hannover.de/holl/tmp/grass_bt_full_2006-02-22.txt
> As I have not received any answers on this (the problem is still
> present) I would like to ask again for some pointers where to start
> looking for the problem.
> It seems to be a GRASS-related problem, since I a can use ogr2ogr fine
> with both Postgres and Oracle...
> But v.in.ogr still fails with a seg fault.
> Thank you for pointing to a starting point
> Best
> Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
