[GRASS5] gis.m
Michael Barton
michael.barton at asu.edu
Wed Mar 1 12:08:05 EST 2006
Kirk,
Just saw the part of your message below. The issue probably is how to
correctly parse database option for your pg database. Maybe I can try a
couple options and you can test, as I don¹t have anything set up in pg at
the moment.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
Date: Wed, 1 Mar 2006 09:09:31 -0600
To: Michael Barton <michael.barton at asu.edu>
Cc: devel grass <grass5 at grass.itc.it>
Subject: [GRASS5] gis.m
Also the "show attribute data" button does not seem to be working for me.
While the "show attibue colmns" butotn returns the output of v.info -c
map=t61v1_working layer=1to the output window:
INTEGER|cat
INTEGER|id
CHARACTER|type
CHARACTER|class
The "show attribute data" button returns:
GRASS 6.1.cvs (minnesota_utm):~ > table=t61v1_working
database=host=localhost,dbname=ts2325 driver=pg
2
It seems that the problem is the 2 at the end of the return. I get the
expected output if I send the first part of the command from the command
line:
GRASS 6.1.cvs (minnesota_utm):~ > db.select table=t61v1_working
Michael, this may be due to the fact that I am using pg for attibute
management. Just thought you should know
Kirk
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060301/6801179a/attachment.html
