[GRASS5] [bug #4138] (grass) nviz don't start from the GUI
Request Tracker grass-bugs at intevation.de
Sat Mar 4 11:09:03 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4138
Subject: nviz don't start from the GUI
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: GRASS GIS Version 6.1.cvs
Please enter your name and error description here. Don't write general statements such as "this could be better" - please explain in
details how a certain problem can be solved or a feature be added/improved. Send different report for different problems. Thanks!
Name: Juan Carlos Torres
Version: I downloaded "version 6.0 (stable) for fedora core 4", but in fact the rpm contains grass61 !
Error description: nviz and d.nviz don't start properly from the user interface.  It seems that the GUI call the command as if it has arguments, and so start directly nviz with no map information.
I have solved the problem modifyng the file d.m.tcl
(at /usr/lib/grass-6.1.cvs/etc/dm/)
changing the calls to this command to term (instead of spawn)
(at lines 671 and  679).
Thanks
Juan Carlos Torres
-------------------------------------------- Managed by Request Tracker
