[GRASS5] RE: [bug #4140] (grass) Nviz doesn't start either from GUI or CLI
Luigi Pirelli l.pirelli at acsys.it
Tue Mar 7 05:55:35 EST 2006
could you send more detailed information with:
from CLI
ddd nviz
 > r elevation=Cheticamp98.5.ave.fill
(ddd or dbx or aother debugger)
after Seg fault type:
 > where
cut&paste result of the stack
please control all linked libraries using command ldd of the nviz and related
loaded shared object.
sometimes nviz doens't start when 3d support driver is not loaded... please
check if correct Graphic Card Driver is loaded... las saturday, nvidia drivers
whas't able to be loaded due to a flag in xorg.conf when PC was using a
particular projector...
bye by Ginetto
www.riade.net
www.acsys.it
Patton, Eric wrote:
> Maciek,
> Perhaps there's another clue here; when I run nviz from CLI, I get:
> GRASS 6.1.cvs (Cheticamp):~ > nviz elevation=Cheticamp98.5.ave.fill
> Loading Data
> Update elev null mask
> Loading Data
> translating colors from fp
> *Segmentation fault*
> (my emphasis)
> Same error occurs with different rasters.
> Hmmm....g.region -p gives:
> GRASS 6.1.cvs (Cheticamp):~ > g.region -p
> projection: 1 (UTM)
> zone:       20
> datum:      ** unknown (default: WGS84) **
> ellipsoid:  wgs84
> north:      5176119.54768
> south:      5166572.33329
> west:       628593.997416
> east:       652873.00618
> nsres:      9.92433928
> ewres:      10.10362412
> rows:       962
> cols:       2403
> Nothing too unusual here?
> ~ Eric.
> -----Original Message-----
> From: Maciek Sieczka via RT
> To: epatton at nrcan.gc.ca
> Sent: 3/6/2006 11:54 AM
> Subject: [bug #4140] (grass) Nviz doesn't start either from GUI
> On Mon, 6 Mar 2006 15:18:49 +0100
> Markus Neteler <neteler at itc.it> wrote:
>> On Mon, Mar 06, 2006 at 01:08:36PM +0100, Request Tracker wrote:
>>> this bug's URL: http://intevation.de/rt/webrt?serial_num=4140
>>> Subject: Nviz doesn't start either from GUI or command line in
>>> 6.1cvs generic binary snapshot
>>> Platform: GNU/Linux/x86
>>> grass obtained from: Trento Italy site
>>> grass binary for platform: Downloaded precompiled Binaries
>>> GRASS Version: 6.1cvs binary 2006-03-04
>>> Upon typing nviz on command line and selecting an elevation raster
>>> in the nviz GUI, the green status bar builds to 100% but nothing
>>> happens afterward. The message box area of the nviz GUI reads:
>>> Loading Data
>>> but no other errors are indicated. The exact same behavior is
>>> observed if nviz is run from the display manager GUI.
>> Eric,
>> can you please post the related
>> g.region -p
> Also please try running your NVIZ command from the CLI and see what
> happens. I just suppose there might be a segfault, which will be not
> visible in the GUI output.
> Maciek
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
