[GRASS5] Layers Clarification
Michael Barton michael.barton at asu.edu
Tue Mar 7 12:43:28 EST 2006
v.category allow you to create and automatically populate a new layer.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Date: Tue, 07 Mar 2006 10:21:58 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Trevor Wiens <twiens at interbaun.com>, GRASS5 <grass5 at grass.itc.it>, Radim
> Blazek <radim.blazek at gmail.com>, Helena Mitasova <hmitaso at unity.ncsu.edu>,
> Martin Landa <landa.martin at gmail.com>
> Subject: Re: [GRASS5] Layers Clarification
> Dear Radim and Michael,
> Michael Barton wrote:
>> Moritz,
>> I want to embellish on Radim's response a bit.
>> ONE vector object can join with can be joined with ONE attribute table for
>> EACH "layer" it has. If it has ONE layer, it can join with ONE table, if it
>> has TWO layers, it can join with TWO tables.
>> Each "layer" is a data field or column (integer format) named "cat". Each
>> vector object has at least 1 cat column ("layer 1") defined by default. You
>> can optionally add more cat columns ("layer 2", "layer 3", ...). Each cat
>> column serves as a key field to make a join with an attribute table.
>> The cat values in different layers can be completely different. For example,
>> a particular vector point can have cat=1 for layer 1, cat=5 for layer 2, and
>> cat=38 for layer 3.
>> The "cat" integers in a "layer" key field must match with a corresponding
>> key field (integer format) in the attribute table you want to join. To
>> continue with the above example, the vector point would join with a
>> line/record in an attribute table whose key field has a value of 1 for layer
>> 1, with a line/record in a DIFFERENT table with whose key field=5 for layer
>> 2, and a line/record in a THIRD table whose key field=38 for layer 3.
>> In this way,  a single vector can be linked with (i.e., one-to-one or
>> many-to-one) multiple attribute tables, *IF* you have defined multiple
>> layers. But ONE layer, can only be joined with ONE attribute table.
> Thanks for your explanations. I now think that I understand layers
> correctly.
> One question: is it possible to automatically create a second layer for
> all features in a file, or does this have to be done via v.digit ?
>> I find this a very useful feature, but agree with Trevor that it needs to be
>> documented better. I wrote up something on the GRASS WIKI that could be
>> added to the docs but I haven't had time to do it yet.
> I agree that it seems an interesting feature, although I do agree with
> Trevor that what you explain above is something you should also be able
> to deal with in the database (either putting all the variables into the
> same table with some objects having NULL values for some of the values
> (but I know that NULLs in databases are not acceptable to everyone), or
> you can work with foreign keys, views and more sophisticated select
> statements. This should actually not be too complicated with the current
> way GRASS works. Or am I still misunderstanding something ?
> Maybe more concrete usage examples (and a bit more extensive than the
> ones that Radim gave) might make it easier to understand the added value
> of layers.
> Moritz
