[GRASS5] [bug #4145] Patch for: (grass) r.patch -z eats holes in data
Cedric Shock
cedricgrass at shockfamily.net
Fri Mar 10 10:51:28 EST 2006
Interested parties,
I have fixed this bug. The attached patch contains both tested code changes
for this bug and rewording of description.html to make it obvious that the
current region heavily influences the output of r.patch
Description:
r.patch: Closes bug 4145 by replacing zero and null values with data and null
values with zeros when using -z flag. Description.html partly rewritten to
describe the effect the current region has on r.patch.
--Cedric Shock
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060310/3d7608cd/grass_bug_4145_patch_noOBJ.bin
