[GRASS5] rasters?
Glynn Clements
glynn at gclements.plus.com
Mon Mar 13 07:37:58 EST 2006
Andrea Antonello wrote:
> > What are you asking, exactly?
> Alright, thanks Glynn.
> About two years ago I wrote the raster reading of GRASS in java for JGrass.
> For the last to years everything worked flawless.
> In the last months something stopped to work, i.e. when the java library tries
> to read a raster map, it fails at the point of uncompressing the raster row.
> Since it worked properly in the past years, I expect that something was
> changed in the GRASS libs, so I was asking if anyone knows what that
> something could be, in order to be able to understand and fix is.
I can only think of two changes:
1. For compressed maps (integer or FP), the size of the row offsets is
sizeof(off_t) rather than sizeof(long). The main consequence of this
is that 8-byte offsets will now be more common, so if your code only
handles 4-byte offsets, it will fail more often.
2. Integer maps can be compressed using either RLE or zlib. Maps which
are compressed using zlib have a value of 2 in the "compressed" field
of the cellhd file.
