[GRASS5] g.pnmcomp and Gamma correction (gis.m slider?)
Glynn Clements
glynn at gclements.plus.com
Thu Mar 16 10:02:56 EST 2006
Markus Neteler wrote:
> while generating RGB composites, I came across the
> problem that sometimes maps appear as too dark
> (also when shading maps).
> Glynn, would it be possible to add Gamma correction
> to g.pnmcomp and, if so,
Possible: yes. Sensible: no.
If needed, gamma correction should be applied before the maps are
rendered, by modifying either the colour table or the cell values
(probably the former).
Maybe r.colors needs a gamma= option?
