[GRASS5] g.copy checking for mapset (from, to)
Martin Landa
landa.martin at gmail.com
Mon Mar 20 05:27:12 EST 2006
Hi Hamish,
2006/3/20, Hamish <hamish_nospam at yahoo.com>:
> > it seems that g.copy does not check if to_mapset exists... Attached
> > patch should fix it (I hope).
> I don't fully understand, do you mean to copy maps into another mapset
> from the current one? That's not supported (or at least I don't think it
> should be).
> The "to" mapset is always the current one, and if that doesn't exist
> you've got bigger problems.
now I understand, I am only confused that I do not get any error
message when "to" is not valid map, e.g.
g.copy rast=dem_srtm at PERMANENT,dem at tempx
the current mapset is "temp", mapset "tempx" does not exist. I only
forgot that g.copy is able to copy a map only to the current mapset...
So sorry for disturbing you...
> + G_message (_("<%s> not found\n"), from);
> fyi- G_message(), G_warning(), and G_fatal_error() all supply a newline
> already, only keep one in the string if you really want two of them in
> the output.
Thanks for note...
Martin
