[GRASS5] Re: [DebianGIS] grass and 64bit
Markus Neteler neteler at itc.it
Mon Mar 20 05:48:15 EST 2006
On Fri, Mar 17, 2006 at 09:19:14PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > Now we (theoretically) can compile GRASS with TclTk 8.4, maybe someone
> > > > who knows how can help to bring FFTW into the modern era as well, i.e.
> > > > to use fftw3 not fftw2.
> > > > #ifdef 's to remain backwards compat with v.2 ?
> > > Markus surely can answer better. Anyway, at least it requires updating
> > > to the new API for 3.1 in gmath. It's not rocket science...
> > > Francesco P. Lovergine
> > IMHO fftw2 dependency is a pain since fftw3 is standard now.
> > Also, we want to modify in GRASS 6.1, so we can remove the
> > backwards compat with v.2.
> > I vote for updating to fftw3 without backwards compatibility
> > to not complicate the things (and to make it happen).
> I've commited fixes to support both 2.x and 3.x.
Thanks, Glynn!
This is a great help for packaging GRASS.
Should we backport it to 6.0.x?
Markus
