[GRASS5] v.in.ogr behaviour
Stephan Holl holl at gdf-hannover.de
Wed Mar 22 05:10:58 EST 2006
Hello Stephan,
[replying to myself again]
On Wed, 15 Mar 2006 09:37:26 +0100 Stephan Holl <holl at gdf-hannover.de>
wrote:
> Hello Lists,
> [crosspost again]
> On Mon, 13 Mar 2006 12:09:15 +0100 Stephan Holl <holl at gdf-hannover.de>
> wrote:
> > Dear list,
> > [sorry for crossposting, but perhaps this is interesting for the
> > GDAL-folks as well]
> > I am working with GRASS6_CVS and Oracle 9i which is compiled into
> > GDAL/OGR 1.3.1. Everything works if the tables in Oracle are owned
> > by the given user.
> > v.in.ogr reports the available layers as follows:
> > v.in.ogr -l dsn="OCI:owneroftables/pw at OCI" layer=DATA1 out=data1
> > Data source contains 2 layers:
> > DATA1, DATA2
> > Removing the -l-switch imports the data nicly and creates dataset
> > data1 inside GRASS.
> > When I create another oracle-user with only
> > SELECT-privileges on that table, the tables inside Oracle are shown
> > like this:
> > v.in.ogr -l dsn="OCI:readonlyuser/pw at OCI" layer=OWNEROFTABLES.DATA1
> > out=data1
> > OWNEROFTABLES.DATA1, OWNEROFTABLES.DATA2
> > Trying to import now, this results in a Segmentation fault.
> > v.in.ogr dsn="OCI:readonlyuser/pw at OCI" layer=OWNEROFTABLES.DATA1
> > out=data1
> > So I assume the dot between user and table produces this?! Perhaps
> > anybody can give me a hint where to look at.
> > Using ogr2ogr works with both users and exports e.g. a shapefile
> > correct.
> > Thanks in advance for any pointers.
> Apparently noone has stumbled over this I will provide as much
> information for the developers.
> I have created a full gdb backtrace[1] of the segfault. But again, I
> do not know where to dig into the problem since I do know what is
> going on there...
> Thank you for having a look what might go wrong here.
Learning to use DDD with Markus help got further information for me.
When I run v.in.ogr through ddd I have severel stacks which can be
investigated.
1.UP: key_value1.c:107
2.UP: key_value4.c:49
3.UP: convert.c:352
4.UP: /v.in.ogr/main.c:384
It currently segfaults in key_value1.c:107 (strcmp).
When I put the lines into comments, recompile and run v.in.ogr with
-o-flag, the dataset gets imported with warning, at least it gets
imported.
So now I know, that there must be something wrong with the
projection-stuff. It seems to me that Markus has investigated something
similar in the bugtracker[1] also dealing with projection-stuff.
I have tried to find some hints in the CVS changelogs for key_value1.c
but I am not sure if they are relevant.
2006-01-04 12:40  markus G_malloc(); alloc() -> G_alloc(); calloc() ->
		G_calloc();realloc() -> G_realloc()
and
2006-02-09 04:08  glynn Use <grass/gis.h> etc rather than <gis.h>
Probably this problem is also relevant with the following changes:
2006-02-12 22:41  cho v.in.ogr segmentation fault fixed
          argument type fixed: OGRSpatialReferenceH * =>
          OGRSpatialReferenceH         OGRSpatialReferenceH is already a
          pointer to void.
2006-02-09 17:58  cho vector/v.in.ogr/main.c: bug fixed: wrong argument
type passed
Does anybody know if this changes require any CVS-versions of GDAL/OGR
or PROJ.4?
Thanks for any comments on this.
	Stephan
[1] https://intevation.de/rt/webrt?display=History&serial_num=4190
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
