[GRASS5] [bug #4205] (grass) v.out.ogr fails
Request Tracker
grass-bugs at intevation.de
Wed Mar 22 12:02:11 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4205
Subject: v.out.ogr fails
Platform: Mac OSX
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 6.1.cvs checked out 18032006
v.out.ogr fails with the following error. It seems to get aprox 25% into the job before failing.
GRASS 6.1.cvs (minnesota_utm):~ > v.out.ogr input=forties type=area dsn="PG:host=localhost
dbname=timber_forties user=kwythers" olayer=forties format=PostgreSQL
Exporting 1314202 areas (may take some time) ...
pg(21246) malloc: *** vm_allocate(size=8421376) failed (error code=3)
pg(21246) malloc: *** error: can't allocate region
pg(21246) malloc: *** set a breakpoint in szone_error to debug
DBMI-Postgres driver error:
Cannot describe table
ERROR: Cannot select attributes for cat = 363284
However, running v.out.ogr on the spearfish dataset ran to compleation,
GRASS 6.1.cvs (spearfish60):~ > v.out.ogr input=soils type=area dsn="PG:host=localhost
dbname=spearfish user=kwythers" olayer=soils format=PostgreSQL
Exporting 737 areas (may take some time) ...
100%
737 features written
WARNING: 1 features without attributes written
The vector that does not works fine in GRASS, but is MUCH larger than the spearfish soils vector.
Could that be the problem?
-------------------------------------------- Managed by Request Tracker
