[GRASS5] Proposed changes to gui.tcl and gis.m
Glynn Clements
glynn at gclements.plus.com
Wed Mar 22 12:34:23 EST 2006
Cedric Shock wrote:
> > I have dropped it into gui.tcl. This makes almost no change, except the
> > proc prnout is no longer needed, and output is formatted very slightly
> > differently.
> I committed this to CVS. By the way, gui.tcl doesn't have a copyright header,
> where could I go look to find where it is from?
cvs log lib/gis/gui.tcl lib/gis/parser.c
The Tcl code that comprises gui.tcl used to be hard-coded into
parser.c; it was moved to gui.tcl in revision 1.34.
IIRC, its first appearance in CVS was the initial 1.1 revision of
parser.c, committed by Radim.
Note: originally, the 6.x CVS repository was used as an "overlay" on
top of 5.x, i.e. only files which differed between 5.x and 6.x were
stored in the 6.x repository. Building 6.x involved checking out both
trees and populating the 6.x tree with symlinks to the "inherited"
files.
