[GRASS5] grass and postgis
Markus Neteler neteler at itc.it
Wed Mar 22 17:18:34 EST 2006
On Wed, Mar 22, 2006 at 09:15:55PM +0100, marcos boullón magán wrote:
> Hello everyone,
> Two questions related to GRASS and PostGIS databases.
> First. When I use v.out.ogr to export a vector map to a remote PostGIS
> database, the result remote table lacks of a "primary key" constrain,
> which causes no problems with some GIS tools (uDIG) and a fatal error
> in others (OrbisCAD). Is there any trick to force a primary key field
> in the new remote table while exporting?
I feel that a "primary key" support should be added but I
am no expert for v.out.ogr.
> Second. Can someone describe the goal of pg.postgisdb command in a few
> lines? I can see it creates a plpgsql language and a
> plpgsql_call_handler() function in a (yet PostGIS-aware?) database
> linked to plpgsql.so system library. Doesn't it duplicate the PostGIS
> installation process step "createlang plpgsql yourdatabase && psql -f
> lwpostgis.sql -d your_database"? And doesn't it mix badly local tools
> (my grass local install) and remote services (my remote postgresql +
> postgis install)? (execution checks for a postgis install available
> locally to pg.postgisdb command, but postgis should be only installed
> in remote server where postgresql is).
I vote for removing pg.postgisdb. It's just an outdated thing, sort
of leftover from GRASS 5.1 times.
Markus
