[GRASS5] v.in.dxf
Fri Mar 24 10:17:39 EST 2006
Huidae Cho wrote:
> I have ported v.in.dxf to GRASS 6 and it's working except for importing labels
> (maybe some database work is needed) and z coordinates (v.in.dxf3d).  I don't
> commit it because I'm not sure if anyone wants this module since there is a
> better(?) alternative, v.in.dwg.  If you think it's worth including the module
> in GRASS 6, please let me know.
I'd suggest that it's worth including. v.in.dwg isn't an option in
many cases due to the licensing conditions on OpenDWG (e.g. it can't
be included in binary distributions).
