[GRASS5] Re: Freetype failure
roger at spinn.net
roger at spinn.net
Thu Mar 30 17:30:26 EST 2006
Thanks, Glynn.
Incidentally, FreeType is not limited to TrueType fonts. It can use several
different font formats. Just the same, its' unlikely anyone is mapping with
symbols beyond the BMP.
Roger Miller
Glynn Clements writes:
> Roger Miller wrote:
>> On composing a reply I found myself repeating things I've said before.
>> I think that by definition that means this discussion is going nowhere.
>> All I can really ask is that someone fix the features that caused my
>> original problems.
> I've applied fixes locally for the size_t and memset() issues, but
> haven't had chance to test them.
> I've attached the patch (against current CVS) if anyone else wants to
> check them.
> I haven't changed from UCS-2 to UCS-4; there doesn't seem much point
> unless there actually exists a TrueType font which uses codepoints
> outside the BMP.
> Glynn Clements <glynn at gclements.plus.com>
