[GRASS5] Enviroment variables in scripts on Windows
Radim Blazek radim.blazek at gmail.com
Fri Mar 31 02:33:33 EST 2006
On 3/30/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Radim Blazek wrote:
> > I found that names of enviroment variables set in g.parser
> > are converted in execlp(?) to uppercase.
> > Consequently variable GIS_OPT_input for example is not defined
> > and script fails. The name of variable was converted to GIS_OPT_INPUT.
> > Any ideas how to resolve this?
> This appears to be done by both Cygwin and the MSys version of bash.
> Windows itself preserves the case of environment variables (although
> lookups are case-insensitive).
> I have no idea how to resolve this, other than changing both g.parser
> and all of the scripts which use it.
OK, I'll change the parser to set both GIS_OPT_xxxxx and GIS_OPT_XXXXX
and scripts in CVS to use GIS_OPT_XXXXX.
That means users' scripts will continue to work on Linux/Mac
and scripts included in standard distribution will also work on Windows.
Radim
> It might be worth checking whether the Korn shell from Microsoft's
> Services for Unix exhibits the same behaviour.
