[GRASS5] features needed for 6.2
Sören Gebbert soerengebbert at gmx.de
Fri Mar 31 04:05:46 EST 2006
On Friday 31 March 2006 06:31, Helena Mitasova wrote:
> On Mar 30, 2006, at 10:01 PM, Hamish wrote:
> >> There already is r.pack/r.unpack in grass wiki add ons written by
> >> Hamish http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassAddOns
> >> maybe Hamish could submit it to CVS to make it easier for users to
> >> find it,
> > No, it shouldn't go into CVS (as is).
> > 1) it's a quick hack
> > 2) I never finished checking if r.in|out.mat was endian-safe
> >     (any one with Matlab on a Mac want to try?, turn on g.gisenv
> > debug)
> > 3) Because Matlab stores data column by column instead of row by row
> > (holdover from FORTRAN I think), the entire map must be loaded into
> > memory during processing. Not something we want for a non-specialist
> > module. (I don't want to rotate the map 90deg either)
> would it be possible to include this as a comment into the script?
> something
> like Cedric has done for r.tileset or v.group, just to make the user
> aware or
> if somebody wants to re-do it.
> > A better approach might be to create a new mapset dir in the current
> > location, copy over the WIND file from current mapset and PROJ_* files
> > from PERMANMENT, switch to the new mapset with g.mapset, 'g.copy @,',
> > then switch back to the original mapset and .tar.gz the entire
> > temporary
> > mapset.
> > Personally I don't use this very often so someone else should take
> > it up
> > if they want it.
> > Other candiates for inclusion are r.in.wms/r.in.onearth and
> > v.out.ascii.db.
> those would be useful to include too.
Cedric wrote a version of r.in.wms which includes the functionality
of booth tools (there is an r.in.wms.onearth).
http://www.shockfamily.net/cedric/grass/r.in.wms-cedric2.tar.gz
This is not much tested and lacks a makefile and the description,
but has the important tiling support for large downloads. :)
I think this should be a candidate for inclusion, if it is tested and documented
properly.
Best
Soeren
> Helena
> > I've never been sure if v.out.ascii.db as the correct
> > approach or if a C module doing the same (or modification of
> > v.out.ascii
> > itself) would be better.
> > Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
