> > Maybe /usr/local/share needs to be predefined somewhere to catch > > that? > > I guess that > $PROJLIB/../share > should be predefined (will catch most cases). except if you didn't use --with-proj-share=, you probably didn't use --with-proj-libs= either and the result will be the same. Worse actually, it parses to: PROJSHARE=/../share Hamish
