[GRASS5] r.mapcalc bug/64bit?
Hamish
hamish_nospam at yahoo.com
Mon May 1 04:01:27 EDT 2006
> # filter command to check if a new frost period starts or
> # an existing one continues:
> GRASS 6.1.cvs (pat):~ > r.mapcalc \
> 'startday=if(modis_t_a_lst1km20040102.daily_min < -2.0 && \
> (startday_previous == 0 || condition_previous == 0), 2, \
> startday_previous)'
> 100%
> GRASS 6.1.cvs (pat):~ > r.info -r startday
> min=-2147483648
> max=-2147483648
> GRASS 6.1.cvs (pat):~ > r.univar startday
> total null and non-null cells: 1136163
> total null cells: 1136163
> Of the non-null cells:
> n: 0
> minimum: nan
> maximum: nan
> range: nan
> mean: nan
> standard deviation: nan
> variance: nan
> variation coefficient: nan %
> sum: 0
No problem, besides r.info (both -r and normal) doesn't translate NULLs.
on a 32-bit P4:
G61> r.mapcalc startday_previous='null()'
100%
G61> r.info startday_previous -r
min=-2147483648
max=-2147483648
maybe init start maps to 0,1 instead of null(),1 ?
in r.info test min,max result with G_is_null_value() ?
remember for CELL maps int can't be set to nan.
Hamish
